[RealTimeSync] Stops if you DO display popups
therube
(I'm on XP, so FFS 10.11.
I'm new to RTS, just experimenting at this point.
I've not finished reading the https://freefilesync.org/archive.php revisions, & I haven't searched here to see if already noted, but...)
If you schedule a RTS & do NOT set it to not show popups, & you do not close the popup prior to the next scheduled sync action (I think that is the deal), then future syncs do not occur.
(I believe that is what is going on.)
Correct, the sync is running as long as the window is open, so another instance can't start. Hide the display windows for unattended syncing
