issue
bowoow
Hi, recently I ran into an issue with multiple sessions running/stuck in background (memory for days)... I had to manually end it... There is no error message or anything... I have attached a screen grab... I have no problem run it manually and successfully... Can someone help??? Much appreciated... Thx...
sflorg
Had same issue that I noticed today also.
bowoow
Hi, how do i provide you the dump file??? I got few samples for you from two different PC's... Thx,
therube
Next, compress the .dmp file as zip or rar and send it to zenju [at] freefilesync.org. If the attachment's size is too large for email, upload it to some free file hoster and send the link instead.
bowoow
Hi, please find below link with compressed file... Thx,
https://www.dropbox.com/s/3skbe7svusl1fhb/FreeFileSyncError.zip?dl=0
Looks like you forgot to either set "Ignore errors" or "Cancel": https://freefilesync.org/manual.php?topic=schedule-batch-jobs
The FFS instances are blocking while showing an error message about conflicts.
