Crash when scanning folders on Mac OS (Mojave) and Nexis Storage
alienlarevanche
Am using your amazing software to backup my folders on a Nexis storage, It worked well until I upgraded the Mac Os system to Mojave, then the app crashes few seconds after it starts the folders scan.
Am using the last version of the app. I've made many tests , the copy work well between folders of hard drives connected to the computer but when I try with the Nexis storage it crashes.
Here is a trace of the activity of the thread before and after the crash. I've noticed many error messages ... but I couldn't figure out the origin of this bug ?
Hope you can help me to solve this issue. Let me know if your need more information.
Kind regards.
Do you also have a call stack for the crash?
alienlarevanche
No sorry , how can i get it ?
I added the error report if it's useful ?
You may have to enable the macOS crash reporting first:
https://freefilesync.org/faq.php#crash
FFS is crashing while trying to write to the sync.ffs_lock file. Most likely a driver bug, but maybe we can work around. Does the following version still crash?
https://www.mediafire.com/file/pe57jcbo8tze1gr/FreeFileSync_11.1_beta_macOS.zip
alienlarevanche
Thank you for this reply, I've tried with the version you sent me , it still crashes.
There are two cases :
1st it takes some time trying to access the storage like 15s then start to scan before it crashes few secondes later
when I try again, it starts immediately to scan before it crashes.
I suspect the crash has something to do with entitlements:
Exception Type:        EXC_CRASH (Code Signature Invalid)
Exception Codes:       0x0000000000000001, 0x0000000000000000
Exception Note:        EXC_CORPSE_NOTIFY
Termination Reason:    Namespace CODESIGNING, Code 0x2
Maybe using the Nexis Storage requires FFS to request com.apple.security.cs.allow-unsigned-executable-memory or the like. FFS however is not sandboxed, so this shouldn't apply.
It seems some apps set entitlements even though they are not sandboxed, while other entitlements only make sense to set when sandboxed. So let's give it a shot. The version below will set these entitlements:
com.apple.security.cs.allow-jit
com.apple.security.cs.disable-library-validation
com.apple.security.cs.allow-dyld-environment-variables
https://www.mediafire.com/file/w98ma50n6xelc3f/FreeFileSync_11.1_beta_macOS(2).zip
If this doesn't work, we need to somehow gather more information about why "EXC_CRASH (Code Signature Invalid)" occurs. Maybe details are logged somewhere.
alienlarevanche
EUREKA ! It works ! It looks like you figured out what was happening :) ! Bravo !
Do I have to keep this beta version or theses changes will be available on the next update ?
Thank you again for your quick support Zenju !
Wow, I had expected more complications! Now I hate cargo cult, so let's find out which of those entitlements did the trick and I'll include it for the next release. I don't think com.apple.security.cs.allow-jit was required, the other ones I'm not sure:
com.apple.security.cs.allow-unsigned-executable-memory:
https://www.mediafire.com/file/i1tu33isk8a7pz6/FreeFileSync_11.1_beta_macOS(3).zip
com.apple.security.cs.disable-library-validation:
https://www.mediafire.com/file/q9dkzvy6ky08bj3/FreeFileSync_11.1_beta_macOS(4).zip
com.apple.security.cs.allow-dyld-environment-variables:
https://www.mediafire.com/file/ht7cl7sgqwgqv6o/FreeFileSync_11.1_beta_macOS(5).zip
alienlarevanche
Hahaha, of course, so here are the results :
com.apple.security.cs.allow-unsigned-executable-memory: It worked !
com.apple.security.cs.disable-library-validation: Crash
com.apple.security.cs.allow-dyld-environment-variables: Crash
Perfect, fixed for the next release!
