Unable to connect via SFTP
woot
FFS version 11.0 [Donation Edition]. Authenticating via the agent, excerpt from the sshd_config:
Protocol 2
AddressFamily inet
Compression delayed
KexAlgorithms curve25519-sha256@libssh.org,diffie-hellman-group-exchange-sha256
Ciphers chacha20-poly1305@openssh.com,aes256-gcm@openssh.com,aes128-gcm@openssh.com
MACs hmac-sha2-512-etm@openssh.com,hmac-sha2-256-etm@openssh.com,umac-128-etm@openssh.com
PubkeyAuthentication yes
HostbasedAuthentication no
PasswordAuthentication no
PermitEmptyPasswords no
ChallengeResponseAuthentication no
KerberosAuthentication no
GSSAPIAuthentication no
IgnoreRhosts yes
GatewayPorts no
AllowTcpForwarding no
X11Forwarding no
UsePAM no
Subsystem sftp internal-sftp
Error returned:
Cannot find the following folders:
sftp://XXX.XXX.XXX.XXX
Cannot read file attributes of "sftp://XXX.XXX.XXX.XXX".
LIBSSH2_ERROR_KEX_FAILURE: Unable to exchange encryption keys [libssh2_session_handshake]
Please update libssh2 so it can be used with the modern cypher-set.
libssh2 feature requests need to be reported here: https://github.com/libssh2/libssh2/issues
Looks like such a request already exists: https://github.com/libssh2/libssh2/issues/457
woot
Are you building against v1.9? Might be worth updating.
Looking at its changelog:
     adds ECDSA keys and host key support when using OpenSSL
     adds ED25519 key and host key support when using OpenSSL 1.1.1
     adds explicit zeroing of sensitive data in memory
     adds additional bounds checks to network buffer reads
     fixed a small memory leak during the key exchange process
     fixed a possible memory leak of the ssh banner string
     fixed various small memory leaks in the backends
     fixed possible out of bounds read when parsing public keys from the server
     fixed possible out of bounds read when parsing invalid PEM files
Are you building against v1.9? woot, 09 Aug 2020, 09:45
Yes.
woot
Yes. Zenju, 09 Aug 2020, 09:57
OK, waiting for v2.0 then...
woot
https://github.com/libssh2/libssh2/pull/468 was merged into the master branch. Pending release...
