Sync and Backup two different folders
wizzard
New to this software. So far, all looks good. I need to sync (Folder A to Folder B). I can create a batch file for this.
However, I also want to add to this batch file (Backup Folder C to Folder D).
Can this be done so I only need to run one batch file?
You can define multiple folder pairs, if desired with different sync settings.
wizzard
You can define multiple folder pairs, if desired with different sync settings. Plerry, 13 Aug 2020, 06:39
Thanks a lot. Took a little getting used to set up but works great! Exactly what I needed!
