Wait the directory is used: "X: \ Image Collection \ sync.ffs_lock" ?
uwe
I always get the error message:
The directory is definitely in use.
There is also no file (also no hidden file) "sync.ffs_lock"
What do I have to do to get FreeFileSync to work again?
n German:
Ich bekomme immer die Fehlermeldung:
Warten Sie das Verzeichnis verwendet wird: "X: \ Bildersammlung \ sync.ffs_lock"
Dabei ist definitiv das Verzeichnis in Verwendung.
Es existiert auch keine Datei (auch keine versteckte Datei) "sync.ffs_lock"
Was muss ich tun, damit FreeFileSync wieder läuft?
FirstSirius
I have the same problem since a couple of days.
What can we do to get rid of this issue?
Thank you in advance.
FirstSirius
There is also no file (also no hidden file) "sync.ffs_lock" uwe, 14 Aug 2020, 11:16
Could be a network driver bug. I can have a look: https://freefilesync.org/faq.php#trace
Christian-Dufner
I have the same problem. I looked up the other solutions but couldnt figure it out. Any further suggestions?
Is it possible that is has something to do with the update? I think it worked before.
Greetings,
Christian
Well, the best way to verify is to install an older version to confirm
