Files not copied/mirrored - desktop.ini
Furatus
Hi!
I'm using this program to keep mirrors and updates of my libraries and for example desktop.ini files are not copied. This makes reconciliation very difficult - almost impossible. Is this intended behavior? Is there a way to force it? I have very complex directory structure and really large number of these files.
Thanks!
Check your filters, it excludes those by default
Furatus
Check your filters, it excludes those by default xCSxXenon, 05 Sep 2020, 14:04
Thanks a lot! It saves me some aggravation :)
