MacOS FFS 11.1 Crashing
Ashteroide
OS: MacOS Catalina 10.15.6
FFS Version: 11.1 & 11.0
My FFS keeps crashing after 'Searching for Program Updates', I initially had this problem but reinstalled 11.1 and it worked fine, I open it up again today and it crashes the same as before. I tried reinstalling but it kept crashing. I unfortunately can't get any proper logs. I'll try a few other methods I can think of and report them back here
Maybe crash reporting is disabled on macOS: https://freefilesync.org/faq.php#crash
Ashteroide
Hi sorry for the later reply, my crashreport is enabled. It just closes, that's all, I've tried 11.2, 11.1 and 11.0, I'll keep going down until I found it. I've tried deleting the FreeFileSync Application Support folder but that didn't work
Ashteroide
I used an application called AppCleaner that removed all the FreeFileSync files, I'll try finding the crash report but it seems to be an internal app problem
Edit: Here's a line I found in the Console app
Oct 17 23:12:19 Ashlees-Macbook-Air com.apple.xpc.launchd[1] (org.freefilesync.FreeFileSync.63096[15145]): Service exited with abnormal code: 13
If you start FFS via the Terminal, maybe this will return more useful information:
/Applications/FreeFileSync.app/Contents/MacOS/FreeFileSync
