Is it possible to save a Filter setup for include or/and exclude rules?
Regards
HÃ¥kan
Save a Filter setup
Your Include/Exclude Filter settings are essentially sync configuration specific and stored in your *.ffs_gui or *.ffs_batch sync configuration files (once you save those).
When your sync configuration comprises multiple folder pairs, you may even use local Filter setting (the funnel-icon in between left-right pairs). Also those Filter settings are stored in your *.ffs_gui or *.ffs_batch sync configuration files.
If you like to modify the default (Exclude)Filter entries (that apply to all FFS syncs), you can edit the GlobalSettings.xml file, by adding, deleting or modifying Items in the xml DefaultExclusionFilter section.
yes
Now also possible via GUI: viewtopic.php?t=8503#p30737you can edit the GlobalSettings.xml file, by adding, deleting or modifying Items in the xml DefaultExclusionFilter section. Plerry, 08 Oct 2020, 14:20
