Synch Failures
when a batch sync is schedule and it encounters an error like a locked file and the option are checked to ignore errors , does the program set an exit code so it can be looked at by the calling job and if its greater than 0 do something ?
See here for exit codes.
The log-file should provide details on warnings and errors.
