0 bytes files (corrupted) from left ends up overwritting good files that are older in the right side.
How can i prevent this?
it would be wonderfull if that min size filter , set to 1 byte min, could filter out those 0 bytes
files in the source region.
Please anyone could help me with a good solution?
newer 0 bytes files (corrupted) overwrites older good files
From what I can see (older FFS version 10.11), setting a (Filter), File size: Minimum: 1 Byte, does filter out 0-byte files.
I can see that interactively in the list of files shown to sync.
(I'm testing with an Update sync, if that should matter.)
I have a list of files to sync, including a 0-byte file, I go to Filter & tell it 1 Byte Minimum: & that 0-byte file no longer displays in the file list.
this is really odd, maybe version? im using 11.2
as you can see in the screenshot, it still shows on mine even with the filter
image failed on previous post
here it go
here it go
tried with 10.11 , same result. dont know if there is any particularity with the 0 byte file as its corrupted. but the main thing is that it is newer than the ok file.
but i tried with a newly created txt , and freefilesync tries to overwrite the txt that has content with the 0 byte txt even though i filtered min size.
in my tests here, the 1 byte filter only filters the destiny side.
it doesnt work on my source (left side)
can you share a screen of yours? maybe i can understand what im doing wrong
anyone? really need helping preventing this behavior
Just tested, and yes, there is a problem. It does only apply that size filter to the destination. Problem is, on a two-way sync, both sides are a destination. I don't see a workaround unfortunately.
It would be a nice add to freefilesync a checkbox with something like:
->Never copy empty files over non empty files
im having a simlar problem but with the current version but nothing is happening ?
I'd don't think so.im having a simlar problem
What is it you're trying to do?
Looks like you're doing a "Two Way" sync (which I'm not really familiar with).
And that being the case, looks like it wants to copy those files from W: that are not on B:, to B: (plus whatever else might be going on that we can't see).
i rolled back the version and re-updated and it looks like that worked
im using the portable version so it may of lost connection or something
they were all 0kb files that did not exsist
i tried running it and saw it was overwriting with 0kb files
not sure why there showing up blank but that is what screen shot i took
