ERROR_FILE_EXISTS [CopyFileEx] on Samba share
mikexx
How do I get rid of theses 29,000 errors?
1) I make sure there are no ".ffd_tmp" files omn the NAS drive and delete any that I see.
2) I run FFS Version 11.3 - 64 Bit - 02/11/2020 and I get the following errors.
3) I'm also left with 30,000 useless "*.ffs_tmp" files on the NAS drive, which I can of course delete once again.
I added the Exclude filter, *~* since this seems to be rated with filepaths that include tilda "~". But these filepaths aren't filtered out when doing the synchronise.
This is more than a little annoying!
"C:\Program Files\Internet Explorer\ExtExport.exe" to
"\\DNS-323-1\Backup\C-Backup\Program Files\Internet Explorer\ExtExport~2693.ffs_tmp".
ERROR_FILE_EXISTS: The file exists. [CopyFileEx]
05:24:55     Error:     Cannot copy file
"C:\Program Files\Internet Explorer\hmmapi.dll" to
"\\DNS-323-1\Backup\C-Backup\Program Files\Internet Explorer\hmmapi~4e04.ffs_tmp".
"C:\Program Files\Internet Explorer\iediagcmd.exe" to
"\\DNS-323-1\Backup\C-Backup\Program Files\Internet Explorer\iediagcmd~a540.ffs_tmp".
"C:\Program Files\Internet Explorer\ieinstal.exe" to
"\\DNS-323-1\Backup\C-Backup\Program Files\Internet Explorer\ieinstal~67ae.ffs_tmp".
"C:\Program Files\Internet Explorer\ielowutil.exe" to
"\\DNS-323-1\Backup\C-Backup\Program Files\Internet Explorer\ielowutil~8737.ffs_tmp".
"C:\Program Files\Internet Explorer\IEShims.dll" to
"\\DNS-323-1\Backup\C-Backup\Program Files\Internet Explorer\IEShims~9dae.ffs_tmp".
"C:\Program Files\Internet Explorer\iexplore.exe" to
"\\DNS-323-1\Backup\C-Backup\Program Files\Internet Explorer\iexplore~0a15.ffs_tmp".
"C:\Program Files\Internet Explorer\sqmapi.dll" to
"\\DNS-323-1\Backup\C-Backup\Program Files\Internet Explorer\sqmapi~2822.ffs_tmp".
05:25:33     Error:     Cannot copy file
"C:\Program Files\NVIDIA Corporation\license.txt" to
"\\DNS-323-1\Backup\C-Backup\Program Files\NVIDIA Corporation\license~f5a7.ffs_tmp".
"C:\Program Files\SoftEther VPN Client\vpn_client.config" to
"\\DNS-323-1\Backup\C-Backup\Program Files\SoftEther VPN Client\vpn_client~467d.ffs_tmp".
ERROR_ACCESS_DENIED: Access is denied. [CopyFileEx]
"C:\Program Files\Windows Defender\AMMonitoringProvider.dll" to
"\\DNS-323-1\Backup\C-Backup\Program Files\Windows Defender\AMMonitoringProvider~751c.ffs_tmp".
"C:\Program Files\Windows Defender\ConfigSecurityPolicy.exe" to
"\\DNS-323-1\Backup\C-Backup\Program Files\Windows Defender\ConfigSecurityPolicy~4b17.ffs_tmp".
"C:\Program Files\Windows Defender\DefenderCSP.dll" to
"\\DNS-323-1\Backup\C-Backup\Program Files\Windows Defender\DefenderCSP~525b.ffs_tmp".
"C:\Program Files\Windows Defender\EppManifest.dll" to
"\\DNS-323-1\Backup\C-Backup\Program Files\Windows Defender\EppManifest~39e7.ffs_tmp".
"C:\Program Files\Windows Defender\MpAsDesc.dll" to
"\\DNS-323-1\Backup\C-Backup\Program Files\Windows Defender\MpAsDesc~455a.ffs_tmp".
"C:\Program Files\Windows Defender\MpAzSubmit.dll" to
"\\DNS-323-1\Backup\C-Backup\Program Files\Windows Defender\MpAzSubmit~c34e.ffs_tmp".
"C:\Program Files\Windows Defender\MpClient.dll" to
"\\DNS-323-1\Backup\C-Backup\Program Files\Windows Defender\MpClient~7a7b.ffs_tmp".
"C:\Program Files\Windows Defender\MpCmdRun.exe" to
"\\DNS-323-1\Backup\C-Backup\Program Files\Windows Defender\MpCmdRun~9340.ffs_tmp".
"C:\Program Files\Windows Defender\MpCommu.dll" to
"\\DNS-323-1\Backup\C-Backup\Program Files\Windows Defender\MpCommu~588f.ffs_tmp".
"C:\Program Files\Windows Defender\MpEvMsg.dll" to
"\\DNS-323-1\Backup\C-Backup\Program Files\Windows Defender\MpEvMsg~dbd8.ffs_tmp".
"C:\Program Files\Windows Defender\MpOAV.dll" to
"\\DNS-323-1\Backup\C-Backup\Program Files\Windows Defender\MpOAV~ca6b.ffs_tmp".
[…]Showing 25 of 28,962 items
Maybe there is something interesting in the logs: https://freefilesync.org/faq.php#trace
mikexx
If I look at the offending line from the Process Monitor screen output I get:
High Resolution Date & Time: 23/11/2020 20:42:08.2455887
Event Class: File System
Operation: CreateFile
Result: EAS NOT SUPPORTED
Path: \\DNS-323-1\Backup\Program Files\Internet Explorer\ExtExport~ba93.ffs_tmp
TID: 8708
Duration: 0.0086388
Desired Access: Generic Read/Write, Delete, Write DAC
Disposition: Create
Options: Sequential Access, Non-Directory File
Attributes: A
ShareMode: None
AllocationSize: 54,784
If this isn't sufficient I can email you the PML file where I have cropped the output before the file creation attempt and the final closing of the source file.
HTH
The burning question, why the EAS error. I associate this with "Exchange ActiveSync Mail Server", but why is FFS using this?
If this isn't sufficient I can email you the PML file mikexx, 23 Nov 2020, 20:51
Yes, it would be great to have another sample of this issue for reference. I already have a similar PML file for Windows 7 which has lead to the following analysis:
This is a Samba network driver bug that hasn't been fixed for years (who's responsible for your network driver? Microsoft?).
The problem is when CopyFileEx detects that the source file has NTFS extended attributes (EA), like in your case, it first tries to open a file handle on the target network location with "Read Data" access right:
Desired Access:    Generic Write, Read Data/List Directory, Read Attributes, Delete
=> this operation fails with EAS NOT SUPPORTED
So far so good. Network doesn't support EA, okay.
Problem: Despite the error, a 0-sized file has been created on the network that was not cleaned up!
Next CopyFileEx tries to skip EA and copy the file normally, so it opens the target handle without EA support:
Desired Access:    Generic Write, Read Attributes, Delete
=> this operation also fails: NAME COLLISION
This is the NT equivalent of Win32 ERROR_FILE_EXISTS! It can't create the file, because a 0-sized garbage file was left over from the previous operation!
Only now CopyFileEx fails with ERROR_FILE_EXISTS and gives control back to FreeFileSync, which is in a bad situation to detect this mess. There is no way to know that this (garbage) file on the network target folder wasn't there before the copy attempt, so it has to leave it there.
mikexx
Many thanks for the explanation. I have emailed you a cropped PML file but uncertain it will give you much additional information.
While I agree that the server leaves a a mess for FFS, it should be apparent to FFS that:
1) There wasn't a xxxx.ffs_tmp file before the error
2) there is a zero length xxxx.ffs_tmp after the error.
Could you not set a flag and look for the file ending, which must be unique to FFS, and zero length, in order to delete a zero length file?
The NAS drive is a D-Link unit running ALT-F which is currently using SMB v1.0
I can run SMB v2.0 but then the file structure beomes invisible to File Explorer, though I can still access the drive by manually by typing in the name/IP address.
Thanks! On Windows 10, the file operations inside CopyFileEx are slightly different:
=> EAS NOT SUPPORTED
Desired Access:    Generic Write, Read Data/List Directory, Read Attributes, Delete, Write DAC
=> NAME COLLISION
Desired Access:    Generic Write, Read Attributes, Delete, Write DAC
=> NAME COLLISION
I can run SMB v2.0 but then the file structure beomes invisible to File Explorer, though I can still access the drive by manually by typing in the name/IP address. mikexx, 24 Nov 2020, 14:29
Would be interesting to know if this is a SMB v1.0 bug that is fixed in SMB 2.0 or if the bug is originating somewhere else.
Could you not set a flag and look for the file ending, which must be unique to FFS, and zero length, in order to delete a zero length file? mikexx, 24 Nov 2020, 14:29
Essentially the question becomes how much hackery is justified to work around this bug in third-party code. OTOH Windows Explorer doesn't suffer from this bug because it isn't using Microsofts very own CopyFileEx. Maybe FFS should get rid of CopyFileEx entirely (which doesn't offer a lot of functionality anyway that couldn't be achieved differently).
mikexx
Right, I'm not sure which version of Samba I'm running but believe it may be 3.6.25. I have the option of SMB1 and SMB2. Both were ticked initially.
Choosing SMB1 and SMB2 over the other or both made no difference. However on the share there is a tick-box for "Inherit Perms" which when ticked made the problem go away.
I have no idea what permissions are those being inherited but I no longer get these hanging zero length files.
I hope this has been of use to you and others.
Chribaa
Hi Mikexx, hi Zenju,
I read your exchange with much interest, as I have the same problem. When FFS tries to copy files from my C-Drive to my NAS (in my case a Synology DiskStation 710+ running DSM 5.2 in the most current version), I get these errors and no files get updated. FFS becomes almost useless this way. I tracked it with Process Monitor - and the above is exactly true in my case as well (EAS NOT SUPPORTED -> NAME COLLISION and left over 0-size .ffs_tmp files)
Interesting is, that FFS can copy files from a USB-Stick (mapped as D-drive) to the DiskStation w/o any problems regardless of whether it is formatted with FAT or with NTFS.
So, I guess the reason for the errors needs to lie in the file-system of my C-drive (The Laptop is a Lenovo Thinkpad X1 Yoga running Win 10 Enterprise in Version 10.0.19042.)
Can you help me with a hint, how I can rectify this?
@Mikexx: when you said you ticked a box for "inherit perms" on the share, I assume, this was a flag in the OS of you NAS-drive, correct? On DSM there is no such flag, as there the default is, that permissions are inherited anyway...
Thanks so much for your help!
Marek-M
I have the same problem with my NAS drive. The error "ERROR_FILE_EXISTS: The file exists. [CopyFileEx]" makes it very difficult to sync data. From what I read, there is little chance that FreeFileSync will handle it. Is it possible for FreeFileSync to create a BATCH file in such a situation, which would contain a list of files that ended with such an error during FreeFileSync synchronization? With such a file it would be possible to manually copy files that FFS skipped due to an error. Below is an example of a few bugs from the first post along with the proposed BATCH file content for them:
*** LIST OF ERRORS [CopyFileEx] FROM FIRST POST ***
*** GENERATED BATCH FILE CONTENT: ***
XCOPY /y  "C:\Program Files\Internet Explorer\hmmapi.dll" "\\DNS-323-1\Backup\C-Backup\Program Files\Internet Explorer\hmmapi.dll"
DEL /f /q "\\DNS-323-1\Backup\C-Backup\Program Files\Internet Explorer\hmmapi~4e04.ffs_tmp"
XCOPY /y  "C:\Program Files\Internet Explorer\iediagcmd.exe" "\\DNS-323-1\Backup\C-Backup\Program Files\Internet Explorer\iediagcmd.exe"
DEL /f /q "\\DNS-323-1\Backup\C-Backup\Program Files\Internet Explorer\iediagcmd~a540.ffs_tmp"
XCOPY /y  "C:\Program Files\Internet Explorer\ieinstal.exe" "\\DNS-323-1\Backup\C-Backup\Program Files\Internet Explorer\ieinstal.exe"
DEL /f /q "\\DNS-323-1\Backup\C-Backup\Program Files\Internet Explorer\ieinstal~67ae.ffs_tmp"
XCOPY /y  "C:\Program Files\Internet Explorer\ielowutil.exe" "\\DNS-323-1\Backup\C-Backup\Program Files\Internet Explorer\ielowutil.exe"
DEL /f /q "\\DNS-323-1\Backup\C-Backup\Program Files\Internet Explorer\ielowutil~8737.ffs_tmp"
jbit
I have exactly the same problem using my D-Link NAS DNS-320L with ALT-F firmware, SAMBA 3.6.25 with SMB 1 and SMB2 enabled. FFS cannot write SOME *-ffs_tmp files in target drive, while other files were written correctly.
I experienced this problem using a Lenovo Thinkpad /480 (Windows 10 Enterprise, build 10.0.19043) managed by enterprise (that includes many restrictive policies to access USBs and maybe other files.
In order to validate the problem, I copied all my files (the files that I was not able to sync before) from Lenovo T480 to my owned destop (Win 10). Then I synced my desktop with my D-Link NAS without ANY problem. FFS does NOT create random *.ffs_tmp files and it syncs perfectly.
Then, I firmly believe that this problem is related either something weird in Lenovo or related to some enterprise company policy that prevents CopyFileEx to work 'freely' as it does in a non-managed computer.
Does it make sense?
Essentially this bug needs to be fixed by Microsoft (either their CopyFileEx or Samba implementation is broken).
It doesn't look like this is going to happen since Microsoft isn't suffering from this bug: Windows Explorer reinvented the (file copy) wheel, and isn't using the system function CopyFileEx.
Let's hack around this: If the failure code is ERROR_FILE_EXISTS and the target file size is 0, FFS will assume the Samba bug described here, clean up the orphan file, and restart file copying using streams instead.
Can you test the following version and see if it fixes the issue? https://www.mediafire.com/file/9ixo27xobw7le66/FreeFileSync_11.15_%255BBeta%255D_Windows_Setup%25282%2529.exe
Marek-M
Hi Zenju!
Unfortunately "FreeFileSync 11.15 Beta" does not solve the problem. I temporarily deal with copying bugs from FreeFileSync. I paste the messages into Excel, where I transform them into commands for the BATCH script. So far, this is a working alternative.
Hi Zenju!
Unfortunately "FreeFileSync 11.15 Beta" does not solve the problem. Marek-M, 03 Oct 2021, 17:11
What do you mean? What (new) error messages are you seeing now?
Marek-M
I still have errors of this type (for 17 different files):
18:49:20    Błąd:    Nie można skopiować pliku
"P:\#FOLDER\FILE.xlsm" do
"\\nas326\#FOLDER\FILE~abc1.ffs_tmp".
ERROR_FILE_EXISTS: Plik istnieje. [CopyFileEx]
The only chance for this error message showing, is that there is some issue with correctly detecting this bug in the beta version. (CopyFileEx shouldn't have been used!) Can you send a Process Monitor trace (https://freefilesync.org/faq.php#trace) for a sync where at least one of these ERROR_FILE_EXISTS occurs that leaves behind an empty ffs_tmp file?
Marek-M, 03 Oct 2021, 18:17
Thanks for the PML file! There are 16 "EAS NOT SUPPORTED" logged.
Question 1 is: Do all of these failures leave a zero-byte garbage file behind, or only some of them?
In the pml file, after CopyFileEx failed with "EAS NOT SUPPORTED", the FFS test version tries to check the file size on the target, but this fails with ERROR_FILE_NOT_FOUND, so the workaround to use an alternate copy routine is not triggered.
Question 2 is: if zero-byte files are indeed left behind each time, why is FFS getting ERROR_FILE_NOT_FOUND? Maybe it's a buffering issue? The following version tries to disable buffering and get an accurate estimate whether the 0-byte target files exists or not:
https://www.mediafire.com/file/iuw2xfehga276tl/FreeFileSync_11.15_%255BBeta%255D_Windows_Setup%25286%2529.exe
watrworld
So any fixes to this issue? FFS is unuseable at this point.
Marek-M
https://www.mediafire.com/file/iuw2xfehga276tl/FreeFileSync_11.15_%255BBeta%255D_Windows_Setup%25286%2529.exe Zenju, 11 Oct 2021, 08:01
FreeFileSync 11.15 2021-10-11 synchronized the files without these errors. Another synchronization in a week - I hope it will also be smooth. Thank you for your help.
NickDickinsonWilde
Using 11.15 beta (2021-10-11) and getting the `ERROR_FILE_EXISTS: The file exists. [CopyFileEx]` message.
Despite no file existing that I can see.
PML sent via email.
Using external harddrive connected to a Telus (Canadian ISP) provided router - model #T3200M.
pkiff
Just quickly popping in to say that this has been an issue for me over the past several months as well. I sync several different computers to files on a Buffalo NAS network drive running Linux and Samba. Like jbit above, I'm experiencing problems on a Lenovo Thinkpad (P52) running Windows 10, but managed by a centralized admin.
I have wondered if the issue is related to a corporate OneDrive and/or crappy corporate Anti-Virus configuration. The files it affects seem to be random. And it only occurs when I initiate the Sync from my corporate machine. If I initiate the sync from my personal machine (also a Thinkpad running Win 10), then I don't get any issues. But once I get a file exists error, the only way for me to fix it when syncing either machine is for me to go find the culprit file locations and delete the 0-byte files that are stopping it from working.
I'm still on 11.14. My corporate install (where I get the bugs) is a free version, my personal install (where I don't get bugs) is a donation version.
watrworld
I'm waiting for a Portable version of 11.15 to try. On my work machine, I do not have admin rights. I did try to install on another laptop and selected the portable version, and moved it over to my corp machine, but it complained that it wasnt installed on the same os. So much for portable!!
https://freefilesync.org/faq.php#portable
Not to derail the thread, but read this for the portable information. You can't just copy them over to a different computer without issue. You have to run it from a USB drive.
Marek-M
FreeFileSync 11.15 2021-10-11 synchronized the files without these errors. Another synchronization in a week - I hope it will also be smooth. Thank you for your help. Marek-M, 24 Oct 2021, 19:37
Next week with backup and no NAS synchronize problems. For me issue is fixed in FreeFileSync Beta 11.15 2021-10-11
watrworld
Not to derail the thread, but read this for the portable information. You can't just copy them over to a different computer without issue. You have to run it from a USB drive. xCSxXenon, 31 Oct 2021, 14:39
Except, that I cannot even start the silent install as it requires admin rights, so I do have to do it from another computer.
You don't use the silent install for the portable version. You haven't downloaded the portable version by the sound of it. Go to your donation page and click the portable download link, not the Windows installer.
PML sent via email.
Using external harddrive connected to a Telus (Canadian ISP) provided router - model #T3200M. NickDickinsonWilde, 27 Oct 2021, 04:15
This seems to be an unrelated issue. E.g. there's \\192.168.1.254\admin\Images\2017\20170313_161923.jpg, and CopyFileEx fails with ERROR_FILE_EXISTS. FFS tries to get its size, and this in fact succeeds with "3.106.383" bytes. Whatever the reason this file exists (maybe you're running multiple syncs in parallel), the ERROR_FILE_EXISTS error seems legit.
Next week with backup and no NAS synchronize problems. For me issue is fixed in FreeFileSync Beta 11.15 2021-10-11 Marek-M, 31 Oct 2021, 21:27
Sounds promising! I can't release the code in the beta in the current form. First need to find out, which setting did the trick:
Are you able to reproduce ERROR_FILE_EXISTS that is leaving behind a zero-byte file with FFS 11.14 for a specific file?
If yes, let's do a few more tests:
1. Are able to copy with this version? https://www.mediafire.com/file/g0dh2z06edwysxd/FreeFileSync_11.15_%255BBeta%255D_Windows_Setup%25287%2529.exe
2. And with this? https://www.mediafire.com/file/6au4qqxd5ej85e9/FreeFileSync_11.15_%255BBeta%255D_Windows_Setup%25288%2529.exe
3. This one? https://www.mediafire.com/file/je3629022tumg9d/FreeFileSync_11.15_%255BBeta%255D_Windows_Setup%25289%2529.exe
watrworld
You don't use the silent install for the portable version. You haven't downloaded the portable version by the sound of it. Go to your donation page and click the portable download link, not the Windows installer. xCSxXenon, 01 Nov 2021, 19:39
Except 11.15 is not yet available as its in Beta, only 11.14 show on my donation page.
Marek-M
3. This one? https://www.mediafire.com/file/je3629022tumg9d/FreeFileSync_11.15_%255BBeta%255D_Windows_Setup%25289%2529.exe Zenju, 02 Nov 2021, 16:10
I will try to do these tests next Sunday - this is my backup day :) Thank you for your patience.
NickDickinsonWilde
PML sent via email.
This seems to be an unrelated issue. E.g. there's \\192.168.1.254\admin\Images\2017\20170313_161923.jpg, and CopyFileEx fails with ERROR_FILE_EXISTS. FFS tries to get its size, and this in fact succeeds with "3.106.383" bytes. Whatever the reason this file exists (maybe you're running multiple syncs in parallel), the ERROR_FILE_EXISTS error seems legit. Zenju, 02 Nov 2021, 14:46
Interesting. I guess I'll look more into it. Definitely not running multiple syncs. One sync and if I'm in (windows) explorer in the folder, I see it flicker as a file is created and then disappears. Thanks.
pkiff
Are you able to reproduce ERROR_FILE_EXISTS that is leaving behind a zero-byte file with FFS 11.14 for a specific file?Zenju, 02 Nov 2021, 16:10
In my case, no I can't - at least not until the error pops up again. When (if) it does I will pay closer attention and do a couple tests. Currently, I'm testing to see if simply pausing OneDrive synchronization before syncing with FFS will eliminate the error. Synced once now with no issues, but I only synced a dozen files. The issue may require larger sync sets to show up.
pkiff
I'm still using FFS 11.14. I ran into this issue again during a sync of about 20 files. One new file to be synced failed with a "ERROR_FILE_EXISTS: The file exists. [CopyFileEx]" error. The error states the correct source file name and path but and shows the correct Buffalo Linksation NAS network folder (starting with "\\LS-220\...." but the destination filename is a temp file, with shortened name like this: "FileNameBeginsCorrectlyThenTilda~4dde.ffs_tmp" file. After the failed sync, there is then a 0-byte .ffs_tmp file left in the folder. That file prevents any further syncing of the original file. But even after deleting that file, I could not sync the original file today. What I had to do was MOVE the original file to the parent folder, then sync everything again, and then it worked. After that, I moved the culprit file back to its original location, and it synced again correctly. So the same file in the same folder failed to sync the first time, but then was able to sync later in the same place.
Initially, I tried this with my corporate OneDrive running in the background as well. I thought that might be the culprit, but even after turning it off, and deleting that ffs_tmp file, in this case, the sync wouldn't proceed until I moved it to another folder.
I don't have any further theories at the moment, but am happy to try 11.15 beta if you are looking for further testing. Or I'll just update to 11.15 when it is officially released and see if that solves the issue.
Marek-M
I will try to do these tests next Sunday - this is my backup day :) Thank you for your patience. Marek-M, 02 Nov 2021, 17:25
I just finished syncing files. I made it using the application from point 1:
All files copied correctly and further application tests from points 2 and 3 were not possible.
Processed items: 302 (664 MB)
but am happy to try 11.15 beta if you are looking for further testing. Or I'll just update to 11.15 when it is officially released and see if that solves the issue. pkiff, 07 Nov 2021, 15:05
When you encounter such a reproducible case again, a test with version 2, and if it fails, version 1 (in that order) would help a lot.
pkiff
When you encounter such a reproducible case again, a test with version 2, and if it fails, version 1 (in that order) would help a lot.Zenju, 08 Nov 2021, 09:22
I ran into the error today with a single file failing out of about 200 changed files that were synced during a manual sync of about 27,000 files using v1.14. Unfortunately, the same file caused errors with both the version 2 and version 1 from those Mediafire download locations in that other post. The error is slightly different as it reads "ERROR_FILE_EXISTS: The file exists. [CreateFile]" instead of [CopyFileEx]. And instead of starting by saying "Error Cannot copy file" it says "Error Cannot write file". But other than that the behaviour for me was the same in all versions.
I was only able to fix it after moving the culprit file and then re-syncing. After which, I could put it back in the same place it was originally, and sync again and all was good.
In this case, my first attempt at syncing was done with OneDrive running. Eventually I tried synching with OneDrive paused. But I still wonder if it would have synced correctly the very first time if I had paused OneDrive before starting the very first sync. I intend to try to remember to pause OneDrive each time from now on before running FFS and see if the error appears again.
The culprit file in this case was an Excel file with an .xlsx extension and a long file name inside a long sequence of subfolders. The total characters used by filename + subfolders was 205 characters.
It seems possible to me that my issues may be unique and not the same as the OP. It does occur on a Samba share, but there are lots of other variables. The Samba share on my local network has restricted user access. I am syncing from a local folder on an encrypted C drive that is in turn synced via OneDrive to a different remote network Microsoft location that requires a corporate login to access. The Samba share is on a virtual drive on a Buffalo Linkstation that is interpreting protocols for access from Windows machines on the network. There seem to be lots of things that could go wrong all along those paths. And I don't have full control over my corporate machine, so there may be anti-virus and/or spyware managed by my corporate admin that is interfering with things that I am unaware of.
As a reminder, I personally haven't had this issue when syncing from my personal machine using the same version of FFS (donation version, though), connected to the exact same Samba network share using similar protocols. It's only my corporate machine where I'm getting stray issues once in a while.
But like I say, I'm going to try to remember to turn off OneDrive syncing my corporate machine from now on whenever I run FFS and I'll see if that solves the problem.
Thanks for your ongoing efforts. FreeFileSync is truly awesome software that I am very grateful for.
Marek-M
When you encounter such a reproducible case again, a test with version 2, and if it fails, version 1 (in that order) would help a lot. Zenju, 08 Nov 2021, 09:22
Today's file backup was relatively small:
Processed items: 46 (74,9 MB)
Using version 2 of the program I did not get any error related to the message "ERROR_FILE_EXISTS". For now, I am planning more backups with this version 2 of the program. When these errors appear again, I will notify you as soon as possible.
Best course of action would be to use 11.14 until a (hopefully reproducible) ERROR_FILE_EXISTS occurs, then switch to one of the betas to see if they can actually solve it.
The error is slightly different as it reads "ERROR_FILE_EXISTS: The file exists. [CreateFile]" instead of [CopyFileEx]. And instead of starting by saying "Error Cannot copy file" it says "Error Cannot write file". But other than that the behaviour for me was the same in all versions.pkiff, 14 Nov 2021, 17:01
It seems to me this is a similar case as OP, but not the same. It's likely the OP case plus adding OneDrive to the mix. The faulty CopyFileEx call is detected correctly by both betas, but it seems the cleanup is not working. Probably because OneDrive is locking the file.
Probably because OneDrive is locking the file. Zenju, 14 Nov 2021, 17:38
Just found a bug in the beta, which fails to properly delete the bogus 0-size file.
=> Back to the drawing board. I'll be preparing two new betas.
pkiff
=> Back to the drawing board. I'll be preparing two new betas.Zenju, 14 Nov 2021, 18:03
I'm happy to test a beta version when/if I encounter an issue again - though your analysis may be correct - and issues with OneDrive are probably very annoying to work around. Thanks again.
Okay let's go for another round:
• First make sure the NTFS extended attribute error is in fact occuring and reproducible by using FFS 11.14. Otherwise we won't know if the betas fixed something or not.
• If it is, switch to the following beta (version 1) and see if this fixed the issue, or post the error message if not. https://www.mediafire.com/file/r32k6b0bcf54nqt/FreeFileSync_11.15_%255BBeta%255D_Windows_Setup%252812%2529.exe
• If beta version 1 doesn't fix it, maybe beta version 2 does?
https://www.mediafire.com/file/ecugo9uio31z71x/FreeFileSync_11.15_%255BBeta%255D_Windows_Setup%252813%2529.exe
Marek-M
I will try to do tests this weekend.
Does it matter for testing whether "FFS 11.14" is standard or "Donation_Edition"?
Does it matter for testing whether "FFS 11.14" is standard or "Donation_Edition"? Marek-M, 15 Nov 2021, 10:28
No, doesn't matter.
Marek-M
I reinstalled FreeFileSync 1.14 and have just backed up to the NAS. Unfortunately (or fortunately :)) no file error occurred.
Processed items: 52 (314 MB)
In a week I can make another try.
john78
When mirroring some folders I get the same message every time. Is there no one (from FFS ?) who knows the solution (software bug ?) ? Do I have to look for another app to secure my folders ?
When mirroring some folders I get the same message every time. Is there no one (from FFS ?) who knows the solution (software bug ?) ? Do I have to look for another app to secure my folders ? john78, 01 Dec 2021, 16:37
Maybe you can help out: viewtopic.php?t=7898&start=30#p31858
watrworld
I now use SyncFolders, also free, works for me until FFS is fixed.
I now use SyncFolders, also free, works for me until FFS is fixed. watrworld, 01 Dec 2021, 19:42
Without someone doing the testing, it can't be fixed.
watrworld
Without someone doing the testing, it can't be fixed. Zenju, 01 Dec 2021, 19:46
I could test if I am provided with a Portable version.
The betas aren't portable, unfortunately.
