[Server 2019] 11.3 not starting
Turnspit
Hi everyone!
With the migration of my Homeserver from Win 10 to Server 2019, I opted to get the donation edition.
Sadly, version 11.3 doesn't start. While Realtime Sync launches normally, the normal FreeFileSync doesn't launch at all. I tested some other version, and every version up to 11.2 works as it should.
Is this some known issue, is there a workaround?
If not, is there a possibility to get the v11.2 of the donation edition and wait for a fix?
Otherwise I'd have to use the normal edition in the meantime...
Thanks in advance! :-)
FreeFileSync might be crashing and Windows doesn't report it.
Can you check Windows Registry (regedit.exe) at the following subkeys
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Windows Error Reporting
HKEY_CURRENT_USER\Software\Microsoft\Windows\Windows Error Reporting
and see if there exists a value DontShowUI that is set to 1, which means that crashes are hidden.
Turnspit
Hi Zenju!
I checked both subkeys, sadly there is no value in any of them or any further subkeys.
Next step would be Process Monitor then: https://freefilesync.org/faq.php#trace
Turnspit
Hi!
I just sent the logfile according to the FAQ to your Mail-address.
There's an error, but the error message is not shown properly. Can you test with the following version and see if you get the message?
https://www.mediafire.com/file/b38i5kzkuiyfpjf/FreeFileSync_11.4_%255BBeta%255D_Windows_Setup%25285%2529.exe
Turnspit
So, just when I wanted to start testing the version in your link, I saw that 11.4 is out.
Downloaded the Donation Edition and - voila - it works.
Thanks! :-)
