Cannot write file "/sync.ffs_lock"
elektrobank
I have been using FFS for years with no problems. Suddenly I'm getting this error on every computer, even my machine running High Sierra that doesn't require disk access. One is running Big Sur, but has every access granted. I see this issue posted around but none of the fixes work. How can I fix this?
Cannot set directory locks for the following folders:
Cannot write file "/sync.ffs_lock".
EACCES: Permission denied [open]
Any change?
elektrobank
Nope, happens on all my Macs, had to switch to another software
This is a warning only and can be ignored.
elektrobank
If you ignore it no files get copied.
If you run a left-to-right Mirror or Update sync, the message/warning
is no problem, as long as said file can not be written to the left-side (source) location.
As long as there is write access to the right location, the sync can and will still run.
However, if the the message/warning concerns the right-side location, your sync will obviously fail, as no file that would need to be copied left-to-right can be written there, because of the lack of write access (Permission Denied) there.
sros
I've been using ff sync for years and just now got this error. Then it wants to write to a 'hard drive name '2'' location. what's up with this?
FFS writes that file to prevent other FFS sessions from running on the same location at the same time. The error means that FFS does not have permission to write it. That could be caused by many things
sros
xCSxXenon, what should i do??
sros
I tried running ffsync on a different group of drives and there was no problem.
Is it trying to write that file to the root of your drive?
"/sync.ffs_lock" is root, but what locations are you trying to sync?
sros
i was trying to sync two external hard drives.
Screenshot of your FFS window would be nice
sros
I restarted everything and when I went to compare the drives again it said they were sync'd so I called it a day. Thanks anyway!
