Paste found files from subfolders to one target folder
Fajn
Hi, I was wondering, if there is any way to just copy files from several subfolders and paste them to one target folder and at next scan it will copy only new files from different subfolders but not the ones already copied.
I think that example will make it more clear.
I have several cameras but each of them use different folder name scheme and it can not be changed. So if I try to copy photos from one it will create a new folder and copy photos there but with another camera it will create new folder structure beside the first one. The problem is that I want photos from both in the same folder.
Something like this.
Sources:
Camera one\DCIM\Set1
Camera two\Camera\Photos\RAW
Target:
Cameras\RAW photos
Not this.
Target:
Cameras\RAW photos\DCIM\Set1
Cameras\RAW photos\Camera\Photos\RAW
No, being a sync program, FreeFileSync (FFS) by default retains the folder structure of files.
But perhaps you can use the manual action described here.
