Hello!
I tried to install "FreeFileSync_11.6_Windows_Setup.exe" on my old Win-XP-Computer, but it didn't work (wrong file format - not 32 bit or not WinXP). Where can I get a Version which runs on Win-XP 32bit?
The computer runs on a location, where it has no Internet-Connection.
Thanks for help
Wolfram
Install on WinXP 32bit
FreeFileSync_10.11_Windows_Setup.exe is the final version for Windows XP.
You can find it here, Apr 11, 2019, https://freefilesync.org/archive.php.
Thanks for your help. But I got another Problem: I want to synch with an Folder on my smartphone. The smartphone and the Folder are shown in the Explorer: "galaxy\card\mydata", but freefilesynch doen't accept it: not with drag/drop, not with the search-window, not with "copy folder name - insert in the freefile field.
Isn't this implemented in 10.11 - or ist there any trick?
Thanks for help
Wolfram
Thanks for help
Wolfram
