For the next version?... If your answer is yes, note this:
- The first question is solved with --accept-license
- The second question is solved with --directory
- And the last one (press a key)?... I think this option is not necessary and should be removed for unattended installation
acg
workaround for this version 11.6 (while releasing the version with the --accept-license parameter):
#!/usr/bin/expect set timeout -1 log_user 0 spawn ./FreeFileSync_11.6_Install.run log_user 1 expect -exact "\r Accept the FreeFileSync license terms? (Enter 's' to show them) \[y/n/s\] " send -- "y\r" expect -exact "y\r Install FreeFileSync into /opt/FreeFileSync? \[Y/n\] " send -- "Y\r" expect -exact "https://freefilesync.org/donate\r \r"
I was expecting (hah) that expect could do what you want, but I hardly ever use it so I didn't want to grapple that task. The .run file can be extracted to get the tar.gz like before.
acg
bgstack15, 17 Feb 2021, 12:44
Many things can be done to solve this problem. What you say, what I posted, etc., but in my opinion the best solution is the parameter --accept-license
Hopefully developers release it with the next version, which I hope will be soon. Thanks
