Freefile sync bitdefender infected
simonroe
Just updated freefilesync to version 11.8 but now getting errors from virus scanner -says infected and moved to quarantine
Now get boot up error from bitdefender saying having to clean system
florentine
the updated signature is blocking install completely now
it's detecting "FreeFileSync.exe" in the installer temp files
https://www.virustotal.com/gui/file/9f1f642d803c7cd6a0ba04578d96f408678fe84842e8dcabc569ce4d336782da/detection
ReggieWaters
Same here. How can this be fixed?
Thank you!
"ai Score=82"
Seems like our AI overlords did not accept the FFS 11.8 offering.
Whatever. Just re-released and bundled with the 11.7 launcher. I have no time for this AV nonsense.
PS: *No code changes* at all between 11.7 and 11.8 for this file. Only an update to the latest Visual Studio 16.9 that released a few days ago...
Wagner
Kaspersky Security Cloud: nothing has been reported.
florentine
"ai Score=82"
PS: *No code changes* at all between 11.7 and 11.8 for this file. Only an update to the latest Visual Studio 16.9 that released a few days ago... Zenju, 04 Mar 2021, 09:05
I already submitted it as a f/p sample as soon as i saw it but dunno when they'll ever get around to it.
thespartan
@zenju Just upgraded to FFS 13.0 and BitDefender is flagging it as infected The file C:\Program Files\FreeFileSync\FreeFileSync.exe is infected with Gen:Suspicious.Cloud.4.Pu2@aOOawQji and was moved to quarantine. It is recommended that you run a System Scan to make sure your system is clean.
FFS 13 - BitDefender.PNG (33.09 KiB) Viewed 6109 times
SuperMatico
Same here, I roll back to the version 12
RoiJaune
Idem here...
People still use third party antivirus?
xmbtjmtqs
Same issue here. It's probably indeed infected on the server side. Better stick with version 12 until this is resolved.
Same issue here. It's probably indeed infected on the server side. Better stick with version 12 until this is resolved. xmbtjmtqs, 15 Sep 2023, 06:18
You should not be so gullible to believe everything your (cheap?) anti virus software reports:
https://www.virustotal.com/gui/file/686443f2e892dbaa01eea988d54e99e6d4177e17daf388846ecfa798d8a2e3c7
xmbtjmtqs
Definitely, I'm paying for that AV and it's not cheap. Same as I paid for FreeFileSync, btw. So I hope this is resolved soon. It's really unfortunate.
Definitely, I'm paying for that AV and it's not cheap. Same as I paid for FreeFileSync, btw. So I hope this is resolved soon. It's really unfortunate. xmbtjmtqs, 15 Sep 2023, 06:31
There is nothing to resolve from FreeFileSync's side. You could contact your AV software vendor and report a false-positive detection.
xmbtjmtqs
Okay, done. Reported through here (if anyone else want to report it): https://www.bitdefender.com/consumer/support/answer/29358/
RoiJaune
It seems that the problem is already solved by the Bitdefender services. I just tried to install the version 13 and I did not encountered any problem. So it works now.
RoiJaune
I hope that when I launch version 13 I will discover a "Dark Mode" button :D
Lobezno
hi, sophos detect lockdown in the setup install...
Gianni1962
Virustotal found none.
https://www.virustotal.com/gui/file/6726da563617cf512ef2cd134b85f0d43789c57b9c88cd2a6ce46619a79b7c51
Same result from my Sophos Endpoint with Sophos Intercept X.
