Hi!
I love FFS and donate regularly as it works so well and makes my life so much easier, so it is worth every penny. But running it on my Mac has a single but annoying flaw that whenever I press "command-w" to close the windows (but not quit the app), FFS asks me if I want to switch the the tabs. This is super annoying, as I have gotten so used to hitting "apple-w", now "command-w" since MacOS 7. Am I doing something wrong? Have I accidentally changed some setting? Does anyone know a way to assign "command-w" to its "proper" (systemwide) function?
Thanks!
Robbe
MacOS "command-w" doesn't to what it usually does
FFS 11.16 doesn't map "Command+W" to swap anymore:
viewtopic.php?t=1663#p32222
