Error with RealTimeSync in 11.8 release under windows
Mac-Gyver
Hello
I'm trying to use RealTimeSync to perform automatic synchro between a folder (managed by windows 8 ) and a google drive.
Whilst the command "c:\path-to\FreeFileSync.exe c:\path-to\file.ffs_batch" launched automaticaly works fine, the command "c:\path-to\RealTimeSync.exe c:\path-to\file.ffs_batch" abort, with the error message shown in screencopy attached below.
Anyone can explain this ? is it normal ?
Read the limitations of RealTimeSync, particularly the third bullet.
Gdrive simply does not support directory monitoring, or at least not the type of monitoring as used by RTS.
nanarife
thanks, and thing helps
