I have two windows servers part of a domain. Win2008R2 and Win2019. I've installed latest FileSync 11.8 on Win2019 server. Although I am logged in as domain admin, I am running the FreeFileSync as admin as well. Both source and target folders have full domain/admin rights. UAC is turned off on both servers.
When I do Update sync, I get the following.
Cannot read permissions of "\\win2008R2\folder1"
Error_elevation_required: the requested operation requires elevation.
[AdjustTokenPrivileges(SeRestorePrivilege)]
I need to copy the ACL permissions since I don't want to redo it it manually. Is there something I am missing?
please advise.
thanks
Shane
Syncing folders with DACL SACL etc
Yes, you missed the documentation.
https://freefilesync.org/faq.php#permissions-error
Thanks for the doc. The purpose of my migration is to preserve the existing ACL and permission in folders and groups in source and gets applied in target. I have tried without "copy DACL, SACL, ..." which it works but the ACLs don't get applied into target which that is going to create a lot of time to re-apply the permissions in target.
I see the further issue, not supported
viewtopic.php?t=8115
viewtopic.php?t=8119
viewtopic.php?t=2732
