a rename feature
alitatli
After comparing if i need to rename a file (because of linux and cloud character occurs errors in file name with CR LF) i can see from left side. But when i rename a file i have to compare again. And it takes so much time. If i can reame a file from the freesyncapp the file list don't need to compare all of it again.
Best regards.
Manual file and folder rename will be available in the next FreeFileSync version:
viewtopic.php?t=6618#p40070
