FreeFileSync Breaking FileHistory
ireJ
I'm using FFS to sync my files into my dropbox folder (and to a seperate hard drive and folder for peace of mind) so I can use dropbox for file versioning I know FFS does this and am trying out File Versioning with FFS but do prefer FileHistory/Dropbox interface (despite Dropbox taking up a lot more ram). I'm syncing it via a mirror because I have files I'm storing in multiple places so storing them in one Dropbox folder isn't practical and cumbersome. I love windows FileHistory and prefer it due to the great UI design and ease of use. But it seems I noticed whenever dropbox syncs a folder called RecycleBin~d1f7.ffs_tmp it then often crashes FileHistory and gives me the error 200. I also run into issues as I use RealTimeSync to sync it in real time but sometimes get a exit code 2 error. It thinks the batch file isn't there when it is but can be fixed with a restart usually
Unable to start a backup cycle for configuration C:\Users\Admin\AppData\Local\Microsoft\Windows\FileHistory\Configuration\Config
I can fix FH by removing the config files but it's doing this multiple times a day :/ Can anyone help?
Normally it makes little sense to backup your recycle-bin.
Therefore, several common locations of recycle bins are already by default in the FFS Exclude Filter, but apparently not yet the dropbox one.
The simplest way to go about, is running a Compare in FFS, and locate the RecycleBinXxxx folder and via a right-click add it to your Exclude Filter. If the last part of the folder-name is not static, you can edit the Exclude Filter and change the relevant line into e.g. *\RecycleBin*\
ireJ
Therefore, several common locations of recycle bins are already be default in the FFS Exclude Filter, but apparently not yet the dropbox one.
The simplest way to go about, is running a Compare in FFS, and locate the RecycleBinXxxx folder and via a right-click add it to your Exclude Filter. If the last part of the folder-name is not static, you can edit the Exclude Filter and change the relevant line into e.g. *\RecycleBin*\ Plerry, 17 May 2021, 14:42
Thank you, I've added that to my exclusion list that should be the cause of the error. I'll let it continue on and see if I get any errors. Cheers!
EDIT Just got the error from RealTimeSync again this is the error:
Command ""C:\Program Files\FreeFileSync\FreeFileSync.exe" D:\SyncSettings.ffs_batch" failed.
Exit code 2
There are a lot of RecyleBin folders in a Dropbox folder I sync. Heres a example:
