Feature Request Wild Cards foro File Paths
BubbaJohn
Greetings,
I have a directory tree that creates a new directory every day based on date (20210429) etc.
There are other directories on this drive that I do not want to sync. Is there any way I can set the sync source to be something like D:\DailyData\202* ? This way I can run this for 10 years without changing any settings :)
I would also need to have directories created that match on the synchronize path.
Thanks,
BubbaJohn
You can not use wildcards in your left or right base location.
There seem to be two options for your use-case
• Use Macros. Those should work in the left and right base location.
• Define your base locations one folder level higher, e.g. D:\DailyData\ and use an Include Filter "\202*\"(instead of the default "*". Filter definitions can work with wildcards.
