Copy subfolders with files to new folder with new structure
Lukaszek
Hi everyone,
I have a problem in which i thought FreeFileSync can help me.
I have a folder with around 500 subfolders which have another subfolders and i need to extract some of lowest tier subfolders to another location and make a new automated rule to check for any changes daily.
Main folder build:
Folder -> Subfolder1 -> Subfolder1.1 -> ID_1101 -> *files*
Folder -> Subfolder1 -> Subfolder1.2 -> ID_1102 -> *files*
Folder -> Subfolder2 -> ID_1201 -> *files*
New folder build:
NewFolder -> ID_1101 -> *files*
NewFolder -> ID_1102 -> *files*
NewFolder -> ID_1201 -> *files*
I made filters to look like this:
\*\*\ID_????\*
\*\ID_????\*
but it only extract proper subfolders from Main folder to Newfolder with path directory but i need to somehow change newfolder build to only have one layer of subfolders. Is there a chance to make it with FreeFileSync and save it as RealTimeSync daily check rule?
That can't work unfortunately. The syncing can and will only sync it so the source and destination have identical structures.
Lukaszek
:( sad panda
so this program is almost perfect ;P
but i think i can manage to do what i want with some kind of batch file in schedule. Wish me luck and thanks for help :)
As a one-off operation it's possible (uncheck "keep relative paths"): https://freefilesync.org/manual.php?topic=tips-and-tricks#copy-to-alternate-folder
Lukaszek
but it has to be automated. It can be in two steps but it has to be done automaticly because i have bad memory ;)
therube
(You could set up folder pairs. But with 500 of them, I doubt the program would take that many?
Not to mention I doubt you'd want to actually do the setting up ;-).)
