FFS latest version11.10 not installing on Xubuntu 18.04.3 - .run installer gives an error about invalid status flag
mrfrank74
Hi All,
not sure what is happening but I downloaded the latest FFS version and uncompressed the .run installer from the tar.gz package.
Double click on installer in file manager does nothing.
I checked the file permissions and it is executable.
It turns out the below error is thrown in terminal:
franco@franco-PC:~$ /home/franco/Downloads/FreeFileSync_11.10_Install.run
dd: invalid status flag: `none'
Try `dd --help' for more information.
Failed to extract temporary files to "/tmp/FreeFileSync_11.10_bMlCKH".
tar: This does not look like a tar archive
tar: Exiting with failure status due to previous errors
Same happens if I run as SUDO.
I tried to use 7zip to open he .run installer, but it says the .run installer is not a 7zip format. Same with TAR archive manager.
Any suggestions?
Thx
The "dd" command on your system doesn't support the "status=none" flag?
What does "dd --help" show?
mrfrank74
~$ dd --version
dd (coreutils) 8.13
Copyright (C) 2011 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>.
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
Written by Paul Rubin, David MacKenzie and Stuart Kemp.
~$ dd --help
Usage: dd [OPERAND]...
or: dd OPTION
Copy a file, converting and formatting according to the operands.
bs=BYTES read and write up to BYTES bytes at a time
cbs=BYTES convert BYTES bytes at a time
conv=CONVS convert the file as per the comma separated symbol list
count=BLOCKS copy only BLOCKS input blocks
ibs=BYTES read up to BYTES bytes at a time (default: 512)
if=FILE read from FILE instead of stdin
iflag=FLAGS read as per the comma separated symbol list
obs=BYTES write BYTES bytes at a time (default: 512)
of=FILE write to FILE instead of stdout
oflag=FLAGS write as per the comma separated symbol list
seek=BLOCKS skip BLOCKS obs-sized blocks at start of output
skip=BLOCKS skip BLOCKS ibs-sized blocks at start of input
status=noxfer suppress transfer statistics
BLOCKS and BYTES may be followed by the following multiplicative suffixes:
c =1, w =2, b =512, kB =1000, K =1024, MB =1000*1000, M =1024*1024, xM =M
GB =1000*1000*1000, G =1024*1024*1024, and so on for T, P, E, Z, Y.
Each CONV symbol may be:
ascii from EBCDIC to ASCII
ebcdic from ASCII to EBCDIC
ibm from ASCII to alternate EBCDIC
block pad newline-terminated records with spaces to cbs-size
unblock replace trailing spaces in cbs-size records with newline
lcase change upper case to lower case
ucase change lower case to upper case
swab swap every pair of input bytes
sync pad every input block with NULs to ibs-size; when used
with block or unblock, pad with spaces rather than NULs
excl fail if the output file already exists
nocreat do not create the output file
notrunc do not truncate the output file
noerror continue after read errors
fdatasync physically write output file data before finishing
fsync likewise, but also write metadata
Each FLAG symbol may be:
append append mode (makes sense only for output; conv=notrunc suggested)
direct use direct I/O for data
directory fail unless a directory
dsync use synchronised I/O for data
sync likewise, but also for metadata
fullblock accumulate full blocks of input (iflag only)
nonblock use non-blocking I/O
noatime do not update access time
nocache discard cached data
noctty do not assign controlling terminal from file
nofollow do not follow symlinks
Sending a USR1 signal to a running `dd' process makes it
print I/O statistics to standard error and then resume copying.
$ dd if=/dev/zero of=/dev/null& pid=$!
$ kill -USR1 $pid; sleep 1; kill $pid
18335302+0 records in
18335302+0 records out
9387674624 bytes (9.4 GB) copied, 34.6279 seconds, 271 MB/s
Options are:
--help display this help and exit
--version output version information and exit
Report dd bugs to bug-coreutils@gnu.org
GNU coreutils home page: <http://www.gnu.org/software/coreutils/>
General help using GNU software: <http://www.gnu.org/gethelp/>
For complete documentation, run: info coreutils 'dd invocation'
Updating to a newer version of Xubuntu should fix this.
mrfrank74
Thx, I appreciate you taking the time to reply.
I am using an old version of Xubuntu on a old laptop with no PAE support and unfortunately I cannot upgrade to a newer version for this reason (any further update will require PAE).
It turns out even older versions of FFS fails to run, ad it needs at least Glibc 2.17 or 2.18,but my version of Xubuntu only has up to version 2.15.
I guess I can only change distro to a lightwieght one a bit more recent (which is is a pain as then I would need to reconfigure the system from scratch) or attempt to compile a newer version of Glibc and even coreutils on current Xubuntu I got.
Thx anyway!!!
