Hi. I'm trying to realtime sync a batch job with multiple folder pairs to an external HDD with no success
Here's how I've configured it. https://imgur.com/KcnIyil https://imgur.com/fOdAab0
When I insert the HDD, realtime sync tray icon turns red and says "monitoring active" but nothing happens. When I reduce the batch job to a single folder pair, realtime sync works fine. Is this a limitation of FreefileSync or Am I missing something.
Realtime sync for a batch jobs with multiple folder pairs not supported?
What folders are RTS monitoring?
Yeah, that's not RTS, that's FFS.
https://freefilesync.org/manual.php?topic=realtimesync
Are you making any changes for RTS to detect? What is your idle time? One of those locations most likely has something changing a file quicker than the idle time is set to. I would try all four pairs individually
Ah ! You're right. I was syncing the Appdata/Roaming folder, whose files constantly change. Anything I can do to automatically sync that folder?
Set up a sync that only works with that folder, and use task scheduler to sync it on a periodic scheduler instead of being monitored.
https://freefilesync.org/manual.php?topic=schedule-batch-jobs
