CURLE_PARTIAL_FILE: server did not report OK, got 425 425 Unable to build data connection
xyzaz
I am getting this error when trying to connect to Xigmanas via FTP with TLS
425 Unable to build data connection: Operation not permitted [curl_easy_perform]
Filezilla works, Cobian Backup works
FreeFileSync works only when TLS is disabled :(
Could be "NoSessionReuseRequired": http://www.proftpd.org/docs/contrib/mod_tls.html#TLSOptions
As of ProFTPD 1.3.3rc1, mod_tls only accepts SSL/TLS data connections that reuse the SSL session of the control connection, as a security measure. Unfortunately, there are some clients (e.g. curl) which do not reuse SSL sessions.
To relax the requirement that the SSL session from the control connection be reused for data connections, use the following in the proftpd.conf:
    <IfModule mod_tls.c>
      TLSOptions NoSessionReuseRequired
    </IfModule>
FFS implements libcurl, and this seems to be a limitation of this library.
xyzaz
WoW! Thanks! I put this option into my FTP configuration and now it works!
