I have recently downloaded FreeFileSync from your site and I'm also new to this forum.
I used a tool called BoxedApp to create a portable FreeFileSync application. I was just
exploring to see if I would be to run this portable .exe on various Windows machines.
I had no issue running the FreeFileSync portable app from the machine I created this portable
EXE. However, when I copied it to another machine, I was getting this error when I ran it:
Installaton files are corrupted. Please reinstall FreeFileSync.
Installation was registered on a diferent operating system.
Does FreeFileSync support application virtualization?
Thank you,
Sydney
FreeFileSync Portable?
Donation edition is required to have a portable copy of FFS. It needs to be run from removable media, or else it gets detected as another installation
Is the donation amount a variable? Is there a minimum required?
