sync.ffs_db error. Advice needed.
loudhvx
Hi all,
I've been using FFS for many years and find it absolutely great, simple, intuitive, and fast. After an operating system, it's probably the most important and most used software I have.
Anyway, I've been using an old version of FFS on windows XP machines and it works flawlessly between them. But I also installed the latest FFS onto a Windows 10 computer and it works, but cannot read the old version of sync.ffs_db, and vice versa.
(I still need the old hardware computers to interface with legacy peripherals at work.)
I'd like to get an opinion on whether I should install an older version of FFS onto the Windows 10 computer, or should I install a newer version of FFS on the XP machines? I see the FFS versions marked as the last one supporting XP. Is that version compatible with the latest FFS version in regards to reading sync.ffs_db?
Sorry, I don't have the exact version number I'm running on XP, but it's been maybe 10 years so maybe the version is in the 3.x range.
I searched a bit, but I could not find info on what versions would be compatible across the different versions of Windows.
Thanks for this great piece of freeware! (I just donated.)
I don't think it's possible. You may be better off disabling 'detect moved files' if you are simply doing a mirror and not a two-way sync. If you are doing a two-way sync, the solution may be to create multiple syncs that are using mirror to 'emulate' a two-way. You would consciously have to run them in the correct order to avoid data loss. Are you transferring data between the two machines?
loudhvx
Thank you. Yes I'm syncing both ways including deletions, to have identical copies of folders on multiple machines (two are running xp and a third is running w10). I work on all of the different machines at various times and want the work to be synced across all.
Was there a point where sync.ffs_db changed drastically, or does every version use a slightly different, and possibly incompatible, file structure?
Most versions within reason are compatible, but XP to 10 is an insane jump
