cannot access to the data of my NAS (french Freebox) anymore ...
Nico
I use FFS since 4 or 5 years, to backup my data in a French Freebox NAS. Everything was working well, until an update of the OS of the Freebox last week.
I can reach the ftp server, but I cannot access to the data : see attachment !
I tried Goodsync and Filezilla, and both are OK !
I know that it is a french Freebox, and that it's not very easy to help with something you don't know well or at all !), but I post my message in case a french user read it and can give me an idea, or if anyone else have one.
Thanks for your reading .. and help !
EDIT: Win7 and FFS 11.12
Likely a TLS issue of either OpenSSL or libcurl: viewtopic.php?t=8463
Nico
Thanks for your attention to my question and for your answer but the tow links you gave in the post you mentionne, are dead ...
https://www.mediafire.com/file/ny8hy3n5l6corxk/FreeFileSync_11.12_%255BBeta%255D_Windows_Setup.exe
and
https://www.mediafire.com/file/khfra8dj930xnru/FreeFileSync_11.12_%255BBeta%255D_Windows_Setup%25282%2529.exe
If you have those two old versions, I'll be glad ...
therube
11.12 has (since) been released, so you can just Download FreeFileSync.
Nico
I still have installed it but the same issue ... ;-(
