Automatic synchronization of the last file
MME-TCInformatique
Hello everyone.
I am using freefilesync to sync backups from a server to Veeam. The backups are done every day and I would like every day after the backup it will automatically sync. But I would like only the last backup to sync and not the entire folder (the folder that contains daily backups).
Do you have a solution for this situation? I thought about modifying the basic generated script but I don't know anything about it.
If anyone can help me I would be very honored, thank you very much.
Have a lovely day everybody.
You could look into macros: https://freefilesync.org/manual.php?topic=macros
You could also look into the time span options
MME-TCInformatique
I think I found what I wanted with the time span options.
Thank you so much.
