It would be much more useful to have fixed dates for filtering instead of week, month, or number of days (or have both). For example if I make an archive of a directory on 14 January 2019, and then want to sync/backup everything new after that date, the existing FreeFileSync method does not work well. The software should have something like:
__ Ignore files dated before mm/dd/yyyy
__ Ignore files dated after mm/dd/yyyy
Otherwise this is mostly a nice project. I donated some money yesterday. :)
Date Filtering Issue
Not sure what exactly you mean, but it seems the time-span option fits your above description.
