I don't know if I'm explaining this right -
but what I want to do is scan a folder with a ton of subfolders
and then copy the files with the filter:
*master*.mp3
and dump those into another folder, without deleting the shortcuts in that folder (that part is easy)
instead, it recreates the entire folder structure.
Also, is there a way to make it so it only goes one folder deep to get the files?
This program is awesome!
Is there a way I could then take all of this stuff and have it do realtime sync?
exclude folders but take their files and dump them into the directory
Nope, that is no longer syncing. FFS can only make the destination look like the source.
viewtopic.php?t=8727
That should be fairly easy with command line though.
As a one-time action you can use this FFS option.
