Hello is it possible to copy files from
C:\Source\* to C:\Source\%Users%\Files\
%Users%: are different folders for example C:\Source\Elmar\ C:\Source\Franz\
so that it copies the files like this
C:\Source\Elmar\test.txt to C:\Source\Elmar\Files\test.txt
C:\Source\Franz\test.txt to C:\Source\Franz\Files\test.txt
Copy Files
Look into using Macro's,
particularly the macro %UserName%
no I mean e.g.
To copy the orner /a/, /b/, /c/ but to subordinate it into one
e.g.
C:\Source\House\Maintenance\test.txt to C:\Source\House\2021\Maintenance\test.txt
C:\Source\Scool\Maintenance\test.txt to C:\Source\Scool\2021\Maintenance\test.txt
e.g.
Not possible all in one shot. You could sync C:\Source\Elmar\ to C:\Source\Elmar\Files and do the same for each user/folder
