I have 2 identical backup names. One works perfectly but the other shows an error and will not open. It just shows an error popup. When I try to delete this one it will not delete and returns me to the error popup.
How can I remove this faulty backup that will not let me delete it? Help will be appreciated.
Faulty backup name will not delete
How are you trying to delete that faulty sync configuration?
I click on it first of all. This immediately gives me a popup error message so I have no chance to do anything else. I have to close the error popup before anything else will work. I am therefore taken back to the beginning.
Where do you click on it?
If that is in the FFS -GUI top left window Configuration, try the following:
Right-click the faulty configuration (instead of left-clicking it) and then select to Delete.
If that does not work:
Just to make sure: Select the correctly working configuration and make sure it is saved (as a *.ffs_gui or *.ffs_batch file).
Then close the FFS GUI (or all FFS GUIs), and open the file GlobalSettings.xml in a text editor (for its location: see here).
Find the section <Configurations> and delete the faulty configuration <Item ... /> and save the GlobalSettings.xml file (in the same location).
When you now open the FFS GUI again, the faulty configuration should be gone.
I closed FFS and restarted again. The faulty configuration name has now disappeared! So I am just left with the good ones. I don't know how this happened but I'm glad it did because I couldn't quite understand your method. My fault, not yours!
Thank you for your help. FFS is a great program.
Fixed. in FFS 11.16 it will be possible to select a broken config file, and to remove it.I click on it first of all. This immediately gives me a popup error message so I have no chance to do anything else. jonalto, 18 Oct 2021, 10:05
