it'd like to eject my USB device when a synchronization has been finished.
And I'd like to distinguish if the operation "completed successfully", "completed without errors" and "completed (with or without errors/warnings)".
And it should be possible to save these options in a configuration (so that every configuration could have different settings for that).
Would that be possible?
[Feature Request] When finished: Eject Disk
FFS has error codes you can evaluate via command line and ejecting a USB is trivial with command line as well. FFS has options to run a post-sync command to run a script to do what you want.
