Is there a way do define multiple directories to backup (synchronize) at the same time, like if you would define a backup plan? These directories would then be stored into the ffs_gui file so that you would just have to open it and synchronize to have the backup?
Thanks - C
Backing up multiple directories
Thanks very much for your quick reply. This is exactly what I was looking for.
