I've tried to sync files between my PC and and OwnCloud drive, mounted as "W" drive.
Using directly, FreeFileSync, it works.
Using the batch generated, it works.
But, if i use the Windows Scheduler, even with maximum rights, it doesn't work :
"Impossible to find following directories :
W:\directory
Impossible to read attributes of the file "W:\".
ERROR_PATH_NOT_FOUND: Specified path not found. [GetFileAttributes]"
What's the problem ?
Thank you
Problem on Owncloud mounted
Mapped drive letters don't carry over to the SYSTEM accout, which is what Task Scheduler uses when running with highest privileges.
