HI!
I'm setting up a Windows Scheduled Task to wake up my computer in the middle of the night and perform a batch backup, I would like the computer to go back to sleep so when saving the batch i checked the "Shut down (Sleep)"-option.
When testing this a couple of times my computer keeps jumping in to sleep mode and I figured a nice feature would be to show a propt "Computer will go to sleep in 20 s" or something so that I can abort this if I'm actually using the computer in the middle of the night.
Scheduled batch that puts the computer to sleep
Try entering your own suitable user defined shutdown command in the "Run a command" box in the Synchronization Settings (F8).
You would need to use a script that detects user interaction and doesn't run the sleep command if there is any. Start with finding out how to write or find a script that can detect user presence before acting.
cmd doesn't really have a good way to go to sleep and allow it to be interrupted.
Nvm, this is easy
Run a CHOICE cmd that defaults to yes after 20 seconds, and set it so choosing no aborts the script instead of continuing and running a command to go to sleep.
Nvm, this is easy
