I want to make sure how file selection in filtered view works.
I had 2 folders compared: 403 identical and 1 different (in content) files.
I removed the different filter so that I could delete only the identical files (403).
I selected all in the right folder and press Delete; FreeFileSync showed confirmation of deleting 403 files.
However, after deletion, the 1 file different in content in the right folder was gone too.
It seems this is a bug or am I not understanding it correctly? It should delete only 403 files, not 404 files as shown in the delete confirmation dialog.
Is it because the parent folder was also selected so whatever files inside were deleted too? Strange.
Deleting selected files in folder
The J:\hwdm3\DCIM folder:
viewtopic.php?t=7059&#p32206
Correct, selecting the parent folder and deleting it deletes its contents also, obviously.
@Zenju,
Thanks for the post, I read it.
As one comment/reply by Plerry mentioned about using FFS for something else that it's intended for, then wouldn't it be better and safer to just remove the ability to manually delete via right-click on selected files?
It's not so obvious that FFS will actually delete all items, including non-empty parent folder. The Delete items confirmation dialog doesn't show the true number of items that will be deleted. It's counter-intuitive for me that a folder that contains unique or different files (non-empty) is considered identical/equal.
