[Suggestion] Rename File on FTP/SFTP
OLLI_S
I have uploaded a file to a SFTP server and deleted the file locally.
Then I recognized that I have to rename the file on the SFTP server.
This is unfortunately not possible in FFS.
So either I download the file (sync it to my PC), rename it and upload it again.
Or I use an FTP client, log in, enter my credentials, switch to the target folder and rename the file.
Both ways are not really "usable / user friendly".
So, please allow renaming files on FTP/SFTP by pressing the F2 key or by the context menu.
Would really increase the usability a lot!
OLLI
Manual file and folder rename will be available in the next FreeFileSync version:
viewtopic.php?t=6618#p40070
OLLI_S
Thank you @Zenju, really apprechiate that!
