Exit code 2
rootuser
Command ""C:\Users\Administrator\Documents\FreeFileSync\FreeFileSync.exe" "D:\batch.ffs_batch"" failed.
Exit code 2
I get this error, can someone help?
I am syncing rclone (gdrive) with local folder. There are about 50,000 files
For possible exit codes: https://freefilesync.org/manual.php?topic=command-line
For details on which error: see the log-file
rootuser
Oh thank you
rootuser
How can I run 2 sync at a time
Just run two syncs at the same time
From/in the FFS GUI:
select multiple saved configurations in the top-left Sync Configurations window.
This will result in a single FFS instance for the combined sync configurations.
Or:
open a second FFS GUI and select another sync configuration to also run.
This will create separate FFS instances per sync configuration.
From the Command-line:
Simply launch each sync configuration separately from the command-line.
This will create an FFS instance per sync configuration.
Or:
Launch multiple sync configurations in a single FFS instance from the command line
by listing the separate sync configurations in the command line behind the
"config file:" part in the command line.
