Filters: Separate "Exclude Folders" from "Exclude Files"
markiloon
hello! thanks for this great program!!!
here a useful feature suggestion:
currently one same filter for excluding Folders AND Files.
it will be much more useful if "Exclude Folders" and "Exclude Files" are separated.
many thanks!!
Marki.
Why would this be more useful?
If you end your Exclude Filter definition with a backslash (\) (Windows) or forward-slash (/) (MAC, Linux) you exclude the folder (and everything in it); if you define anything following your last slash, it will exclude files.
markiloon
hmmm...
because there are use cases where you want to sync the folders but not the files.
Possible with FreeFileSync 11.24: viewtopic.php?t=9475#p34605
markiloon
that is great!! many thanks!!!
