Batch Does Not Autostart
kcsoundman@gmail.com
I've created a batch file and when started it does the comparison portion then goes to the Syncronization and stops. I want the batch file to run until completion but it waits for someone to push the Syncronization button. How do I get it to be completely automatic???
Apparently, you run the *.ffs_batch file from the FFS GUI.
You should run it from a command prompt (see here),
or as a scheduled task (see here)
