Size conflict when sync with sharepoint
uknowx5
Hello I have a problem.
The window on the left is a
windows folder, the window on the right is a folder on my computer that syncs with Sharepoint.
When I start the synchronization, it copies me from left to right correctly. I do this process every night. But I see that, if I don't make any changes, after a while it marks them as "show conflicts".
It must be that sharepoint adds a few small bytes when uploading it to its cloud, but there is really no change.
How can I make it only synchronize by date and not by size?
therube
(All I will say is that is an absurd thing for it to do, SharePoint Modifies Files on its Own.)
uknowx5
is it absurd that sharepoint does it or absurd my proposal that there is an option that synchronizes by date of modification?
is it absurd that sharepoint does it or absurd my proposal that there is an option that synchronizes by date of modification? uknowx5, 18 Aug 2022, 09:54
Sharepoint obviously. It's like you put your precious art collection in a store house and they scribble all over it with a pencil to help with their bookkeeping. I can't fathom how Microsoft developers came to the conclusion that this is "OK".
uknowx5
Oh okay thanks.
As a curiosity, this does not happen with Onedrive. I have another folder synced only with Onedrive and I have no problems.
David.P
Hello all,
I can confirm this exact behavior of SharePoint vs. OneDrive.
Unfortunately, this means that I will probably have to switch from FreeFileSync to another sync tool that can handle this issue. I'd rather not do that though, as I like the speed, ease of use and uncluttered UI of FreeFileSync so much.
Is there a workaround available already, or are there any plans to add a "Compare" mode that ignores file size?
David.P
As an update, this is what the SharePoint sync looks for me when someone has renamed 1 or 2 folders on the local server...
And that's only about a third of the length of the FreeFileSync preview window.
Is that probably all down to SharePoint changing the file sizes online?
Perhaps it is possible to somehow get a handle on this problem via the database? For example, by saving which files are considered identical despite their different sizes?
2023-11-24_100155.png David.P, 24 Nov 2023, 09:14
This is unrelated to the thread topic. That long list is likely showing a 'move' action for each of those files, since the parent folder name is changed. It's hard to know exactly because that picture is super duper low resolution
David.P
This is unrelated to the thread topic. That long list is likely showing a 'move' action for each of those files, since the parent folder name is changed.xCSxXenon, 24 Nov 2023, 19:29
Puh, if it's unrelated, the problem is even more severe since then it is implied that FFS shows 2 times 500 files as changed when actually only the parent folder containing those 500 files has been renamed.
That true?
That true? David.P, 24 Nov 2023, 20:03
It's not showing them as 'changed', it's showing them as 'moved'. Which they kind of are, they used to be in "X:\Folder1\OldFolderName" and now they are in "X:\Folder1\NewFolderName". FFS has to represent that those files are changing paths somehow and saying that they are "moving" is the chosen way
David.P
True, but I wished there was a better way of showing that just a folder's name has changed, other than showing each single of the 500 unchanged files contained in that folder two times as "changed" in different places...
Kevin Cl
I have the same problem with a Sharepoint and the sync of a local folder is there a workaround available already, or are there any plans to add a "Compare" mode that ignores file size?
Or to make sure that if the destination file is different to always use the source file.
Or to make sure that if the destination file is different to always use the source file. Kevin Cl, 10 Mar 2025, 11:30
That would be using "Mirror" syncing
Kevin Cl
I found the solution opening a ticket with Microsoft support.
Sharepoint Online by default, use a fonction that modifies the file to add metadata. I used the following commands to disable the parser fonction.
Here’s a general procedure you can follow using PowerShell:
Connect to your sharepoint site :
Connect-SPOService -Url https://contoso-admin.sharepoint.com
Connect to SharePoint Online:
$adminSiteUrl = "https://yourtenant-admin.sharepoint.com"
$userName = "yourusername@yourtenant.onmicrosoft.com"
$password = "yourpassword"
$securePassword = ConvertTo-SecureString $password -AsPlainText -Force
$credentials = New-Object Microsoft.SharePoint.Client.SharePointOnlineCredentials($userName, $securePassword)
$ctx = New-Object Microsoft.SharePoint.Client.ClientContext($adminSiteUrl)
$ctx.Credentials = $credentials
Get the list:
$siteUrl = "https://yourtenant.sharepoint.com/sites/yoursite"
$ctx = New-Object Microsoft.SharePoint.Client.ClientContext($siteUrl)
$list = $ctx.Web.Lists.GetByTitle("YourListName")
Disable Parser:
$list.ParserDisabled = $true
$list.Update()
$ctx.ExecuteQuery()
I found the solution opening a ticket with Microsoft support. Kevin Cl, 14 Mar 2025, 14:55
Wow, after so many years someone has found an actual solution! Thank you very much.
moseshull
I could not get the script provided to work so I used this one.
Source Website
https://github.com/29039/29039s-useful-stuff/blob/main/m365-sharepoint-online-set-parserdisabled.md
Script 1 - Prerequisites installation stage 1 (Run as Admin):
#Prerequisites installation stage 1 (Run as Admin)
#https://chocolatey.org/install
#https://nodejs.org/en/download/package-manager/#windows
Set-ExecutionPolicy Bypass -Scope Process -Force; [System.Net.ServicePointManager]::SecurityProtocol = [System.Net.ServicePointManager]::SecurityProtocol -bor 3072; iex ((New-Object System.Net.WebClient).DownloadString('https://community.chocolatey.org/install.ps1'))
choco install -y nvs
#powershell needs restarting for nvs to actually work
Write-Host "Please exit powershell and re-open" -ForegroundColor Green
Pause
exit
Make sure you EXIT powershell after you run Script 1, or Script 2 won't work.
Script 2 - Prerequisites installation stage 2 (Run as Admin):
#Prerequisites installation stage 2 (Run as Admin)
#https://pnp.github.io/cli-microsoft365/user-guide/installing-cli/
nvs add lts
nvs use lts
npm install -g @pnp/cli-microsoft365
Script 3 - Change the ParserDisabled to true (No need to run as Admin):
(Make sure you update the $SiteURL and $SiteList as applicable)
#Actually use the CLI for Microsoft 365 to change ParserDisabled to true (No need to run as Admin)
#vars
$SiteURL = "https://contoso.sharepoint.com"
$SiteList = "Documents"
#lets go
m365 version
m365 login --authType browser
$SiteID = m365 spo list get --webUrl $SiteURL --title $SiteList --properties "Id" --output "json" | ConvertFrom-JSON
m365 spo list get --webUrl $SiteURL --title $SiteList --properties "Id,ParserDisabled"
m365 spo list set --webUrl $SiteURL --id $SiteID.ID --parserDisabled true
#end it
m365 logout
