Data integrity question
Alexal
Do I understand correctly: when I do a mirror sync, the original files remain untouched?
Do they stay intact even if sync stops, power is lost, network is lost, or other failures occur?
therube
Correct. Source files are not modified in any way.
If the sync stops, source is unchanged.
Target stands at where ever things were when it stopped.
All else falls under the purview of the OS gods.
(Note the difference between a Mirror & an Update sync, Synchronization Settings.)
Alexal
Thank you!
