Do *.ini files need to be included in a mirror sync.
If not, how do I exclude?
John Perrone
ini file extensions
You should figure out what the purpose of the .ini files are and then determine if you need them or not. By default, FFS excludes desktop.ini files because they are not necessary for backing up or restoring.
https://freefilesync.org/manual.php
