Edition Windows 10 Pro
Version 21H2
Installed on 2021-11-24
OS build 19044.2130
Experience Windows Feature Experience Pack 120.2212.4180.0
Installation was attempted twice - before and after Windows update, chkdsk /v/f, sfc /scannow amd dism restore health was used to insure that all is OK.
Win10 FFS crashes
There should be a crash dump file on the desktop (hopefully).
Should I zip and upload the last one?
yes
Sorry, the file is ~100 MB (108,000Kb). If it's important, I can try to upload it to my google drive and share the folder?
@Zenju. The dump file is uploaded to my google drive into a shared folder. If you email me, I will reply with the link.
Thanks, the beta worked.
