I used an older donation-version before I updated yesterday. I guess I should've kept the old working version, because now I get an error telling me:
"File "X:\Documents\Files\FreeFileSync backup config\SyncSettings Batch-file" does not contain a valid configuration
Unexpected file extension: ""
Or something like it. Translated from Norwegian. How can I fix this? It worked perfectly with the older version.
Could I please get a link to an older donation-version to downgrade to a working one, please?
Please help. :)
After updating to 11.27 I get Unexpected file extension: ""
I believe the issue may be that the batch files now need to specifically have a ".ffs_batch" extension?
So something like:
See if adding ".ffs_batch" as an extension gets you working.
I don't believe you can download older donation-versions (only current).
Older non-donation are here, https://freefilesync.org/archive.php.
See also, viewtopic.php?t=9611.
So something like:
X:\Documents\Files\FreeFileSync backup config\SyncSettings Batch-file.ffs_batch
Thanks for the quick reply.
Upon futher inspection, it's already named SyncSettings Batch-file.ffs_batch
The file I'm using was created through FFS, and not through some weird "hackery" I did either, so if the program did it's thing correctly, this shouldn't fail. The batch-files was probably made using 11.14 a year ago.
Reinstalling everything will probably fix things (or just creating the batch file from scratch on the new version), but I'm hoping that it wouldn't come to that. I was hoping there was an easier fix to this. I've found the donation version of 11.22. I'll probably revert to that one and stick to it. That should work.
In your .ffs_batch file, does the second line say:
<FreeFileSync XmlType="BATCH" XmlFormat="17">
Yes, the first two lines are as follows:
<?xml version="1.0" encoding="utf-8"?>
I do have an FreeFileSync backup config.ffs_gui in the same folder, though. That shouldn't matter, I guess.
